Effects
Amplify selection center frequency
Boost or cut a peak centred on the middle frequency of a spectral selection.
Applies a single peaking EQ band to a spectral selection, centred on the middle of the selected frequency range and as wide as the selection. Where Amplify selection lifts or drops the whole band evenly, this shapes a peak or a dip around one frequency, which suits narrow problems such as a single ring or resonance.
Where to find it
Effect → Spectral tools → Amplify selection center frequency.
Making the selection
This effect works on a spectral selection, so the track must be showing a spectrogram first — see Toggle Spectral View. Drag in the spectrogram to select a time range and a frequency range. The effect takes its centre frequency and its bandwidth from that selection.
Controls
- Gain (dB) — −24 to 24, default 0. How much to boost or cut at the centre frequency. At 0 the effect does nothing.
Notes
Because the bandwidth comes from the selection, a tall selection gives a broad, gentle curve and a short one gives a narrow, surgical band.
A 10 ms fade at each end of the selection blends the processed region into the audio around it.
Last updated
