Skip to content
Timeline
Clear Loop Region
Remove the loop region from the timeline entirely.
Removes the loop region altogether, leaving the upper half of the timeline ruler empty. This is different from Toggle loop region, which only switches looping off and keeps the region for later.
Once the region is cleared, playback runs on to the end of the project as normal, and you draw a new region from scratch when you need one.
Where to find it
Right-click the timeline ruler and choose Clear loop region, or press
Shift+Alt+L. It is also in the Looping submenu.
Last updated
